Odd Bore Job
General racing discussion.
Odd Bore Job
Postby graipaip on Fri Nov 23, 2012 4:42 pm
Ok all you Engine guys. Come across something today kinda got me stummped and also interested all at the same time. Got a 327 in on trade sapose to run ( never herd it run ). so me being me i tore it apart to see how i screwed my self. LOL well all looks good has some good parts to it BUT. 1,3,5,2 are .030 and 4,6,8,7 are standard. Now this engine has been balanced and there is no signs of it ever comming apart from a blow up or anything. So i am trying to figure out is this some old guys idea gone wrong or is it some sorta racers way of making power or Lots of RPM.
Not sure where it would help anything or do any good but just seams to be to " on purpose " to be a mistake on the builders part. Come on weve all built an engine with a case of beer before but could you really screw one up the bad and eavenly all at the same time.
graipaip
Re: Odd Bore Job
Postby msims on Fri Nov 23, 2012 5:32 pm
is it .030 or .003 over
Re: Odd Bore Job
Postby 8I MALIBU on Fri Nov 23, 2012 10:27 pm
Could just be a remanufactured motor from autozone or oreillys. I know when I worked at the Aaron's Automotive plant here in Joplin they did stupid stuff like that all the time.
81 MALIBU 406/TH350 11.07 @120 mph with a 1.51 60 foot.
91 CAMARO 355/TH350 13.09 on street tires and 12.22 with slicks. All stock suspension and no subframe connectors!
8I MALIBU
Re: Odd Bore Job
Postby graipaip on Sat Nov 24, 2012 10:02 am
Its stamped .030 on the 4 of the pistons. Just kinda odd that eaven with there being diffrent size pistons in it i have seen that. But to be placed in the block the way they are is where its strange to me. Then to have the 2 bolt to 4 bolt conversion on it ( which i did not state above ) and to be all balanced out that can't be a Autozone motor.
graipaip
Re: Odd Bore Job
Postby msims on Sat Nov 24, 2012 10:30 am
are u sure the 4 pistons are standard or are they .030 tht had ink marking numbers rather thn stamped # on thm??? the ink burned off
Re: Odd Bore Job
Postby graipaip on Sat Nov 24, 2012 10:52 am
got out the mic 4.00 on the standard and 4.279 to 4.299 on the 30 over side i dont have an actual bore scope all i could use was my mic on the top ridge. There is no build up on the ridge as the motor does not have much run time on it.
graipaip
Re: Odd Bore Job
Postby graipaip on Sat Nov 24, 2012 11:10 am
here is a pic of one of the pistons Stamped.
graipaip
Re: Odd Bore Job
Postby toddmoore4114 on Sat Nov 24, 2012 1:14 pm
L2256 trw is a 350 piston.......
toddmoore4114
Re: Odd Bore Job
Postby graipaip on Sat Nov 24, 2012 1:21 pm
Yep it is. Casting number shows 68 to 79 350 or 327 ( 3970010 ) i just went with the 327 just because i had my hopes up when i got it. lol
Not going to pull the crank out to check any further at least not till i get to here it run then maybe i will.
graipaip
Re: Odd Bore Job
Postby msims on Sat Nov 24, 2012 2:49 pm
4.00 then .030 over ould be 4.030 not 4.279 - 4.299 ,,,you mean 4.0279-4.0299
Re: Odd Bore Job
Postby 8I MALIBU on Sat Nov 24, 2012 4:28 pm
Yea sounds like that was definitely done on purpose. I wonder how they got it to balance out with different size pistons?
8I MALIBU
Re: Odd Bore Job
Postby secondwindracing on Wed Nov 28, 2012 10:32 pm
the way you are measuring it you mise well use a tape measure. you have to use a dial bore guage to get the rite reading.dave
secondwindracing
Re: Odd Bore Job
Postby ssbarracudafan on Fri Nov 30, 2012 11:20 am
This is common for a part store reman.. As far as balancing, that is easy for a shop. It use to be a way to cheat on a "stock" class car, leave #1 stock and bore the rest. Becouse tech would only check #1, thats why now they check cylinders at random. :ubergeek: :nice:
ssbarracudafan
Re: Odd Bore Job
Postby amcamx on Fri Dec 14, 2012 6:16 am
What you can get by with, on an internal balanced motor, seems to be a lot.
Heavier .030 over popup domed pistons, and not be balanced, and then take it to 8,000rpm, etc.
I ran a 273 crank in a .040 over 340 motor for 18 years, street, and strip use. It did shake some at 7,200rpm.
I took a Chev 400 external balanced motor, in to be balanced, and they had a fit. I had damaged a piston, and bought a new one, and it was 31 grams too heavy. That is about an once, and they said the piston cannot be lightened that much.
The shop said that the pistons can be heavy or light, but they must be the same.
How can you call a Chev 400 balanced anyway, with over three pounds on the outside of the Flywheel.
Return to Bench Racing
