serpintine belt spueak
Postby wekan on Sat May 05, 2012 8:26 am
I have a 1992 chevy silverado with 255,000 miles on it. The belt is noisy. I have replaced all suspect pulleys and belt. If put dust a small amount of baby powder on it is quiet for15 to 20 miles. Some one suggested the pullies are highly polished and need to be scuffed. Anyone else had this problem and solved. Thanks Joe
wekan
Re: serpintine belt spueak
Postby pepsiman 31 on Sun May 06, 2012 9:57 pm
have you though about your belt tensioner it could be a little weak could also be a noisey bearing some where like in the tension pulley
pepsiman 31
Postby wekan on Wed May 09, 2012 5:03 pm
I replaced the tensioner about 2 years ago, it could be bad got it at napa, the idlers are new the only orginial pulley is the power steering pulley all the others came with engine i rebuilt and had less than 100,000 miles. I think i will replace tensioner and see if that does the trick. Thanks Joe
wekan
Postby pepsiman 31 on Mon May 21, 2012 8:15 am
I was wondering if you found that belt or bearing noise
pepsiman 31
Postby wekan on Tue May 22, 2012 7:14 pm
I have not found the problem yet, replaced the tensioner and tensioner pulley on saturday and it still makes noise,
wekan
Postby wekan on Wed May 23, 2012 1:42 pm
slowly starts making noise, barely noticable at first then keeps getting louder. I have cleaned every thing several times.
I have replaced all idler pulleys, tensioner, newer alternator, cleaned all grooved pulleys, they all match, the fan cluch seems ok. When it starts making noise i put a very small amount of baby powder on the power steering pulley, because that is handy as i keep my baby powder beside the radiator, before start up and it is quiet for 20-30 miles. I have put 2 new belts on, not a waste as i always have had a spare, so i am out of ideas. My real mechanic friend says to turn up the radio.
the
wekan
Postby msims on Wed May 23, 2012 4:38 pm
belt tension good ,,,,maybe someone has replaced something wth something wth a little smaller pulley sometime before so belt is loose
Postby badboyztoy on Wed May 23, 2012 8:24 pm
this is the same problem i had and i did the same thing replaced belts and pulleys still squeels, i was using a cheaper brand serpintine belt so i got a gates belt and it fixed the problem
badboyztoy
Postby wekan on Thu May 24, 2012 10:45 am
I will continue my quest for a squeak free truck, thanks for help, and let everyone know what solution works.
wekan
Postby msims on Thu May 24, 2012 11:18 am
sure fire cure////// full coverage ins., can of gas and a match
Postby wekan on Fri May 25, 2012 10:42 am
I have been driving this old truck for a long time not worth getting full coverage, insurance cost more than worth, and i intend to keep driving it until the wheels fall off. Usually can fix any thing without much expense so i wil just keep trying to fix. When i bought the new tensioner it came with the idler pulley and it was a little bigger than the one i had installed when replaced engine. I just put on a new belt in the last month, i do not remember brand , at a cost of $41. Thanks again for all the help. Joe
wekan
Postby DN on Fri May 25, 2012 12:55 pm
I went thru a deal similar to this a few years ago on a.....don't remember what.... it turned out to be the friggin' water pump. With the belt off, the pump shaft had quite a bit of slop. Sometimes it made a God-awful squawking noise and sometimes it didn't. Replaced the pump and no more noise.
DN
Postby OLD YELLER on Fri May 25, 2012 3:20 pm
I had a bad squawk for quite a few years....Finally figured out that it was my wife.....Got a new one,all's quiet again..... :mrgreen: :mrgreen: :mrgreen:
Postby msims on Fri May 25, 2012 5:33 pm
if putting babypowder on it makes it stop i cant think waterpump bearing is the problem
Postby wekan on Tue May 29, 2012 5:06 pm
Love is grand- divorce is 180 grand. Water pump is new when replaced engine. Some one suggested that a pulley might be highly polished. What if spray a salt water solution on my suspect pulley, the power steering unit - let is dry overnite- put belt back and take off. Anyone use rusty pulleys on an rr??
wekan
