377 good or bad? need opinions
Postby six-point on Fri Aug 17, 2012 10:21 am
im looking at doing a 377 with a voodoo x cam 525/546, 570 max lift beehive valve springs, hydraulic lifters, dual timing chain, double hump heads, 750 edelbrock. would like your guys opinions on if that would be a good set up or not. or what i should change to make it a better set up
six-point
Re: 377 good or bad? need opinions
Postby six-point on Wed Sep 26, 2012 7:42 pm
:layrubber:
six-point
Postby ken goddard on Thu Sep 27, 2012 5:41 pm
what are you going to use the motor in.
ken goddard
Postby six-point on Wed Oct 03, 2012 9:34 pm
Third gen camaro with a 350th trans & will have a 4 link rearend with 3.73 posi.
six-point
Postby zziggy on Thu Oct 04, 2012 6:44 am
The old fuelie heads will hold you back a bunch on power.
They where OK for 283's even mild 327's.
But the new engines need new heads. The Pro-Filers are OK as are Brodix IK200, even the Edelbrock and Trick Flow 195 heads are pretty good as is.
Postby six-point on Tue Oct 09, 2012 5:16 pm
ok well i changed the heads im going with the 92 305 heads which had the bigger ports & cam change to voodoo x 560/580 lift & 600 max lift beehive valve springs
six-point
Users browsing this forum: No registered users and 2 guests
