316?
316?
Postby six-point on Sat Apr 13, 2013 2:07 am
i have a 5.0l HO 305 .060 over with what all the serial numbers on the crank has it listed as a 350 crank. what would be the cubic inch of it? because i cant figure it out, also if all my connecting rod bearings are listed as 10 over would the main bearings be the same. need info asap thanks
six-point
Re: 316?
Postby msims on Sat Apr 13, 2013 6:55 am
305 and 350 use same crank ,,smaller pistons ,,,rods will b 10 under not over (had to be turned smaller to be smooth again) ,,just depends on mains wht ever it took to make smooth again
Re: 316?
Postby six-point on Sun Apr 14, 2013 1:30 am
thanks, i ran the bearing number 2555cp 10 so those would be 10 under & not over
six-point
Users browsing this forum: No registered users and 2 guests
