2005 F-150 brake rotors getting hot
Postby 84foxbox on Wed Jun 19, 2013 5:18 pm
My 05 f150 4x4.
New pads
New rotors
New lines all within a week old
Its still smokin the pads and glowin cherry red at night.. other that the calipers everything is new they felt good while compressing the pistons back in. Anyone had this problem or knows a fix please let me know. Hopefully this fix is easier than my mustang post. I'd appreciate any info.
Thank you jesse..
1984 Ford Mustang GT (sbc)
2005 Ford F-150 Lariat 4x4
2004 Dodge Neon SRT4 Stage 2
2011 Ford Fusion Sport
Re: 2005 F-150 brake rotors getting hot
Postby msims on Wed Jun 19, 2013 5:53 pm
proportioning valve or master cyl.
Postby toddmoore4114 on Wed Jun 19, 2013 6:14 pm
Did you change all 3 hoses ?
toddmoore4114
Postby WAR1 on Thu Jun 20, 2013 4:46 pm
Both rotors or only one side
WAR1
Postby 84foxbox on Thu Jun 20, 2013 5:23 pm
Both but the pass side is hotter.. I just changed the two hoses one on each side off the caliper
Postby toddmoore4114 on Thu Jun 20, 2013 7:20 pm
change the center one .....
toddmoore4114
Postby msims on Thu Jun 20, 2013 9:42 pm
are we talking about the front or rear
Postby toddmoore4114 on Fri Jun 21, 2013 6:43 am
My bad I thought he was talking about the rear !
toddmoore4114
Postby amcamx on Fri Jun 21, 2013 4:09 pm
Is there excessive drag, with the wheel off the ground? If so, the piston may be stuck in the caliper.
Postby WAR1 on Fri Jun 21, 2013 10:21 pm
If its both rotors look at the master
WAR1
Postby 84foxbox on Mon Jun 24, 2013 8:29 am
Yea going down the road there is a lot of drag. Not sure bout when its off the ground..
Postby pepsiman 31 on Tue Jun 25, 2013 6:37 pm
The Master cylinder has a check valve to replive pressure could be bad if its a old cylinder then check free play in brake pedal if not enough the bounnce of it could build up pressure slowly with out you knowing it first check that master cylinder if it is sludgy looking fulid i woud change it some pins that are pushed by the pedal are adjustable
pepsiman 31
Postby pepsiman 31 on Tue Jul 02, 2013 10:13 am
I'm wondering if you got your brake problem fixed and what did you find
pepsiman 31
Postby 84foxbox on Fri Jul 05, 2013 7:47 pm
The brake calipers got replaced and its smooth stopping. They were just not releasing
Users browsing this forum: No registered users and 3 guests
