Pushrod??
Pushrod??
Postby hoggieman racing on Tue Aug 27, 2013 6:55 pm
Havn't bought a set in a long time, any impressive small block pushrods you would recomend, deals? Thanks :layrubber: .
Re: Pushrod??
Postby OLD YELLER on Wed Aug 28, 2013 8:12 pm
I still use wooden ones that I make on my woodlathe......If you need a set,let me know......
web 46.jpg (102.27 KiB) Viewed 542 times
Re: Pushrod??
Postby doorracer on Sun Sep 01, 2013 8:43 am
Look at the Trend pushrods. I bought a set for my SB. 3/8" x .080 wall moly, 2 different lengths for ex. and in., 210° 5/16 ball tapered on one end, standard 5/16 reduction on the other, laser etched with size, black oxide coated. $125.00 One of the best deals I have found. They make them in .025" increments instead of the normal .050" like most.
http://trendperform.com/products/pushro ... -products/
Curtis
doorracer
Re: Pushrod??
Postby hoggieman racing on Mon Sep 02, 2013 7:37 pm
Good info Curtis. Thanks. There's this other guy named Curt trying to sell me on the idea of lightweight wooden pushrods! Seemed like a nice Guy. Salesman maybe.
Re: Pushrod??
Postby secondwindracing on Mon Sep 02, 2013 11:20 pm
manton and trend is the best out there..Dave
secondwindracing
Re: Pushrod??
Postby DN on Mon Nov 18, 2013 9:05 am
Speaking of pushrods...... Other than checking heads for clearance, would a person have to do anything special to run a 3/8" pushrod in a SBC?? Oil volume would be a lot more wouldn't it? Would that create any sort of an issue?? Just curious. :ubergeek:
DN
Re: Pushrod??
Postby doorracer on Mon Nov 18, 2013 10:09 am
Typically in a small block you have to run some sort of offset to clear the intake port. I am running Yella Terra shaft rockers and the intake rocker has .150" of offset to help clear the 3/8" I am running. Or you can run an offset lifter. Oil volume in the pushrod is negligible in my opinion.
Curtis
doorracer
Re: Pushrod??
Postby DN on Mon Nov 18, 2013 10:35 am
Thanks Curtis. :nice:
DN
Re: Pushrod??
Postby zziggy on Mon Nov 18, 2013 5:03 pm
Are these wooden pushrods Oak, Hickory, Walnut, Pine or Balsa?
Re: Pushrod??
Postby OLD YELLER on Sat Nov 23, 2013 11:04 am
I usually use Silver Maple so they look like the metal ones...(Get it ? SILVER Maple) Man we must be bored!!
468 Big Block Chevy.jpg (110.65 KiB) Viewed 250 times
Re: Pushrod??
Postby DN on Tue Nov 26, 2013 1:45 pm
Just an FYI.... I found out from a guy at Trend that they supply Comp Cams with all their pushrods. And from what I have seen, buying the Comp brand is quite a bit cheaper than getting them from Trend. :ubergeek:
Question about off-the-shelf pushrods. Does anyone use Manley pushrods or know anything about them? They seem like a good value.
DN
Re: Pushrod??
Postby hoggieman racing on Tue Nov 26, 2013 2:13 pm
Ended up going with another set of Trickflow pushrods, have had no issues over the last ten years with them. Thought about going Balsa, that Salesman didn't talk me into it though! :shocked:
cron
