holley carb wont idle down?
Postby greenmachine on Mon Sep 02, 2013 7:52 pm
heres my problem.
i have a stock 351w in my 49 ford sedan.
it idles high with the pcv hooked up.
idles around 1000 with the idle shut off.
unhook pcv and it idles much better.
it has done this on 3 600 holleys
any ideas would be great
if it isnt ford it isnt driving no offense to you chevy guys
greenmachine
Re: holley carb wont idle down?
Postby OLD YELLER on Mon Sep 02, 2013 10:20 pm
Is the pcv valve broken or stuck wide open? Shouldn't make that much difference.......
Postby greenmachine on Tue Sep 03, 2013 11:19 am
i dont think they are bad.
i have one on each valve cover.
you can shake them and they rattle back and forth
greenmachine
Postby motorplex88 on Tue Sep 03, 2013 1:42 pm
Does your distributor have a vacume advance ? Could have a vacume source to the distributor tied in with the pcv's vacume source? Just throwin stuff out there.
motorplex88
Postby greenmachine on Tue Sep 03, 2013 7:45 pm
yes it does.
advance is hooked to front port on carb
pcv is hooked to the big port on the side
greenmachine
Postby nelson on Tue Sep 03, 2013 8:26 pm
Crazy idea but if u just unhook one pcv and leave the other hooked up does it idle better. I personally was told to hook my pcv to a vacuum port straight to the intake and have had no issues. Just an idea. Maybe try that and see what it does. Maybe having two hooked up is causing the carb to get too much of a vacuum signal or draw? Hope that is of some help. If not, disregard this post! Lol
Postby OLD YELLER on Tue Sep 03, 2013 8:27 pm
Use only one pcv valve,put a breather on the other side.....Two pcv valves would be too much of a vacuum leak...
Postby motorplex88 on Wed Sep 04, 2013 8:09 am
Sounds like your distributor is hooked up to the proper port. What the fellas have posted above I think have nailed down ur problem. I did'nt think it clear through, but 2 pcv's can't operate properly on that amount of vacume produced, thus only creating the formentioned vacume leak. Be gentle while kicking me to the curb. :oops:
motorplex88
Postby msims on Wed Sep 04, 2013 9:48 am
is your linkage binding up ?? id try unhook linkage leave return spring hookedup so it wont run away with itself and elimanate linkage as the problem
Postby greenmachine on Wed Sep 04, 2013 11:28 am
im gonna give that a shot with the valves and linkage.
i'll keep you posted guys.
thanks a ton for the help
greenmachine
Postby greenmachine on Sun Sep 08, 2013 6:17 am
it was to much pcv. one valve was the ticket.
thank you again
greenmachine
cron
