battery ??
battery ??
Postby 80BU on Tue Sep 17, 2013 6:17 am
Is it possible that a battery has enough power to start the car just fine, but not have enough fire power to run the HEI ignition properly?
80BU
Re: battery ??
Postby pepsiman 31 on Tue Sep 17, 2013 7:52 am
Any thing is possible you should check differnt points for voltage drop the modern battery's of today are hard to test
pepsiman 31
Re: battery ??
Postby gto on Tue Sep 17, 2013 11:55 am
are you running a alt ? hei take aroun 11 volts or more to run right. I put a alt on my gto years back, it run alot better after that. :layrubber: :nice:
gto
Re: battery ??
Postby hoggieman racing on Tue Sep 17, 2013 1:15 pm
Pickup 1-2 mph with an alternator!!! Had a coil that was weak in a HEI, caused me a few headaches.
Last edited by hoggieman racing on Wed Sep 18, 2013 2:43 am, edited 1 time in total.
Re: battery ??
Postby 80BU on Tue Sep 17, 2013 2:55 pm
Yep, it has an alternator. Could it be the problem? Thing ran fine two weeks ago, then last week it was popping & cracking like it was dying. I have gone thru the carb & replaced everything in it. The plugs are still showing black, but I am wondering if it's because it's not getting enough fire. I jetted it down from 413 square to 401 & 404. It's crazy because I've run the 413 jets for 1 1/2 years, no problem, now it's fowling the plugs. I think it must be electrical. Tried unhooking the tach also.
80BU
Re: battery ??
Postby nelson on Tue Sep 17, 2013 8:50 pm
Could your module in the hei be going bad? When they get weak it did kind of the same thing to me and I went through the carb thinking it was a fuel thing too. If u have another hei laying around then pull it out of that one and try in yours before you go spend the cash on a new one. Just my two cents. Hope it helps.
Re: battery ??
Postby zziggy on Wed Sep 18, 2013 2:04 am
The ALT gives a higher voltage. Typically 14.4-16 volts so it charges a 12 volt (13.2 volt) battery and run the accessories like a standard ignition, blower motor, ECM, PW etc.
Re: battery ??
Postby amcamx on Wed Sep 18, 2013 6:41 am
In a car that is old, you can have a lot of electrical problems, if the stock wiring harness is used.
So,for the things that are used for racing, fuel pump, ign etc, they should be hot wired from a good 12v source, like battery, or starter solenoid, to a switch and fuse. This way, you can have 12v where you want it.
With a T pin, you can puncture the harness, and take voltage readings.
Most race cars are low on voltage, that is why some use 16v.
Re: battery ??
Postby pepsiman 31 on Wed Sep 18, 2013 8:45 am
If you are using a stock HEI with a vacuum adv. the wire's to the module will flex an breake connection so check them
also the rotor will burn through I used to put a dab of the die electric grease down in the pocket to get more life out of the rotor be sure to check the cap for cracks and carbon tracking that's my nickel's worth
let us know what you find
pepsiman 31
Re: battery ??
Postby 80BU on Wed Sep 18, 2013 4:50 pm
What I've done SO FAR trying to find the demon.
Completely rebuilt the carb.
New fuel lines.
New fuel pump.
Emptied cell to check for dirt, ect.
Tried a different battery.
New plugs.
New plug wires.
Double checked timing - twice.
Took the dizzy apart & checked it with a fine tooth comb. Nothing I could see. It would almost have to be the coil if it's the dizzy.
I borrowed another dizzy from a friend today, so I will try it tomorrow & see if that's it.
If not, don't call the fire departmant when you see smoke. :lol:
80BU
Re: battery ??
Postby nelson on Wed Sep 18, 2013 6:29 pm
If it is the coil or module I am not aware of any way to test it or to see if its bad. Maybe use ur dizzy with another coil then use another dizzy with ur coil etc. By changing just one thing at a time should help u pinpoint the culprit. I am interested in finding out what it is too. Hate to learn at anothers expense! LOL. Keep us updated
Re: battery ??
Postby pepsiman 31 on Thu Sep 19, 2013 5:40 am
If your system has an external coil don't rule out checking that coil wire that got me once a long time ago
pepsiman 31
Re: battery ??
Postby toddmoore4114 on Thu Sep 19, 2013 7:50 am
Change the cap & rotor I've seen them look OK and be bad .
toddmoore4114
Re: battery ??
Postby pepsiman 31 on Thu Sep 19, 2013 11:35 pm
you changed almost everything should also change the cap and rotor to finish up a tune up this is what
toddmoore4114 and I said earlier about the cap and rotor about the only thing next would be try a differnt coil
many years ago they had a coil tester for the old style but not anymore
pepsiman 31
Re: battery ??
Postby 80BU on Sat Sep 21, 2013 3:53 pm
Put in a different distributor......same problem.
Put on a different carb..........same problem.
I think I will retire BU for this year. I am TIRED of messing with it.
80BU
Next
