battery ??
Re: battery ??
Postby nelson on Sat Sep 21, 2013 4:18 pm
Stupid idea but have u pulled a valvecover yet? Maybe a broke spring or flat lobe? Just a thought
Re: battery ??
Postby msims on Sat Sep 21, 2013 7:33 pm
what about a vaccum leak ///intake gaskets or a vaccum line letting it suck air and not fuel air mix thru the carb
Re: battery ??
Postby 80BU on Sun Sep 22, 2013 7:04 am
nelson wrote:Stupid idea but have u pulled a valvecover yet? Maybe a broke spring or flat lobe? Just a thought
Yep, did this too. Hydrolic with roller rockers. Checked the springs & rockers/valves to make sure nothing had somehow backed off. Everything seemed fine.
msims wrote:what about a vaccum leak ///intake gaskets or a vaccum line letting it suck air and not fuel air mix thru the carb
I tried to check these the best I could. Put on a new base gasket, just because. Sprayed every connection or gasket area with carb cleaner & got no reaction of any sort, so I don't think this is it.
@#$%&, maybe it's a bigger issue than I thought.
80BU
Re: battery ??
Postby msims on Sun Sep 22, 2013 10:11 am
some this bullsht carb cleaner that they sell wont burn /// wth valvecovers off spray past pushrods so it will come up under intake to check bottom side of gaskets
Re: battery ??
Postby 80BU on Sun Sep 22, 2013 11:51 am
Well, I just went ahead & pulled everything. Intake gaskets were excellent. No sign anywhere of a leak. No broken springs. No bent pushrods, yep I pulled them too. I'm going to move on down & check to make sure it didn't jump time or something. s***, I wasn't doing worth a crap in the points anyway. :lol: 8 races & 4 of them I didn't even make an elimination pass because the car kept screwing up.
80BU
Re: battery ??
Postby amcamx on Sun Sep 22, 2013 4:26 pm
What is the car doing, that is not right?
What is the Battery voltage, sitting, at idle, reved up?
What is the Dist Batt +, ign on, at idle, reved up?
Black plugs could be fouled, and misfire even after changing Carb, and Dist.
Broke valve spring, Cam going bad, or even Vacuum, or Egr leaking. Will a Vacuum Gauge read correct, at idle, and down track?
Does a Timing Light flash, show a misfire? If so, which ign wire?
Is the fuel pressure correct, at idle, and down track?
Does a Comp test show good on all cylinders?
With a Reluctor pickup, if it drops just one cylinder, it can cause the others to misfire!
Re: battery ??
Postby 80BU on Thu Sep 26, 2013 7:18 pm
Well, got around to doing a compression check today. Every cylinder was between 190/200. Guess that is ok?
80BU
Re: battery ??
Postby nelson on Sun Sep 29, 2013 7:32 pm
Have you pinpointed the culprit yet? Was wondering if you have found what it was. Thanks
Re: battery ??
Postby 80BU on Mon Sep 30, 2013 5:06 am
Not 100% sure at all. I don't usually use the front & back intake seals. I use permatex. When I started to clean up the old rear seal, there was a piece about 3/8" that was missing. I don't know if it had blown out or if I tore it out getting the intake off. I guess I will find out, if I can ever get time to work on it again.
80BU
Re: battery ??
Postby pepsiman 31 on Fri Jan 31, 2014 9:28 am
I don't believe a hole in that silacone would bother what you have going on , have you found anything else
pepsiman 31
Re: battery ??
Postby back on track on Thu Feb 20, 2014 8:00 pm
Could be a vacuum leak. Spray alittle wd40 or Carb cleaner around Carb seeif idle changes
If it stops being fun it's time to quit
back on track
Re: battery ??
Postby back on track on Fri Feb 21, 2014 7:08 pm
Guess I should read all the posts. Hehe
back on track
Previous
