f150 Heater went out?
Postby 84foxbox on Mon Nov 25, 2013 7:55 pm
05 F150. Just drove it this morning and it blows air just will not get warm even after 40 mins of driving. Anyone know what it could be?. I felt carpet under dash board and its all dry thinking heatercore was leaking. And it has correct amount of coolant. Let me know.
1984 Ford Mustang GT (sbc)
2005 Ford F-150 Lariat 4x4
2004 Dodge Neon SRT4 Stage 2
2011 Ford Fusion Sport
Re: f150 Heater went out?
Postby nelson on Mon Nov 25, 2013 8:14 pm
Check to see if the vents run off vacuum. I have had the vacuum line go bad and not operate the vents. Just a thought. Does it blow out any heat anywhere? The vacuum thing happened on a 90s era truck so not 100% on something that new.
Postby durty on Mon Nov 25, 2013 10:25 pm
Thermostat stuck open
never bring show to a go fight...
durty
Postby Big John on Tue Nov 26, 2013 11:41 am
Probably the blend door to the heater core is stuck. It can be hard to get to, most are behind the dash. There are at least (2) two blend doors. One is for the heater core the other is for the vents.
We had a Ford Windstar van we had to move the door by hand every winter. Ford says you have to remove the dash to change it, the cost at Ford was very high. It is a very common problem with all Fords.
Hope this helps.
John Hutinett
Chanute, Kansas
NHRA 5844
Big John
Postby pepsiman 31 on Tue Nov 26, 2013 4:30 pm
If the heat gage show's normal operating temp and you can hear the blend doors move then you might try back flushing the heater core some of them have the inlet and outlet on top so this cause's them to fill with rust you can push enough out for it to work
pepsiman 31
Postby pepsiman 31 on Mon Dec 02, 2013 12:05 am
It's been a few day's was wondering what you found out on your heater problem
pepsiman 31
Postby zziggy on Mon Dec 02, 2013 5:34 am
make sure the radiator is full.
Postby hoggieman racing on Sat Dec 07, 2013 9:23 am
I talked to Foxbox/No2 and he said the damn thing started working again the next time out. I do have a friend that had to replace his heater core on a F250 V10 the other day, he's hot again. Thanks for the advice Everyone!
Postby 84foxbox on Mon Dec 16, 2013 9:17 am
Fixed. By it self some how.. thx mokan
Postby Larry Jr on Mon Dec 23, 2013 9:36 am
Those years of fords were notorious for the impeller wheel coming apart in the water pump.
Thats the classic symptom no heat, guage will show normal temp, seen several with exact problem
Most likely your water pump
Larry Jr
Postby Don Avondet on Wed Dec 25, 2013 10:42 am
Might try to check for HVAC codes with a good scanner. If its electrical like a blend door motor it will have stored a code.
Don Avondet
