comp cam ?
comp cam ?
Postby rascal on Sun Jan 26, 2014 9:11 pm
hows any ran a comp thumper cam it seems like wen its idleing it loses vacum to the carb
rascal
Re: comp cam ?
Postby durty on Sun Jan 26, 2014 11:18 pm
the thumper cams usually have quite a bit of duration, hence they wont build very much vacuum, may be able to put a vacuum canister on it and it should help with the low vacuum at idle
never bring show to a go fight...
durty
Re: comp cam ?
Postby Siebert_Performance on Thu Mar 06, 2014 10:18 am
A vacuum canister is a good idea, also what is your base timing set at? If timing is low, advancing it will help.
Luke Siebert
Owner / Operator
http://www.siebertperformance.com
Siebert_Performance
Re: comp cam ?
Postby amcamx on Fri Mar 07, 2014 6:04 am
I put a 350 horse cam in a 350 with 8.5 comp, and it would not idle at all. That cam is stock for a 327 or 350, and has .450 lift and about 268 duration. But it is for 11-1 comp, and would not run below 1,800 rpm.
I put in Rhodes lifters, and then the Vacuum went up to 20 in drive, at idle. Instant throttle response.
14.6 sec and pulled the wheels? That is low end torque.
Re: comp cam ?
Postby zziggy on Fri Mar 07, 2014 12:52 pm
Thumpers are for cruising the Sonic. They're a cam that is supposed to SOUND wicked even though it's not/
The Thumper series is a poor choice for a real performance application. A real performance cam and the shortblock and heads to support it are your best choice.
A Mild HYD roller may not rumble a lot but it can make you plenty of power with complimentary engine parts..
Re: comp cam ?
Postby rascal on Sat Mar 08, 2014 12:29 am
the vacum can fixed it
rascal
