Engines, Parts and Carb Selloff!!
Got some extra wheels, heads or other parts to sell? Post them here.
Moderators: mokangena, DN, scottab, Carl Blanton, fish2222
Postby LM14 on Wed Feb 27, 2013 10:21 pm
380” Short Block SOLD!
359” Complete intake to pan SOLD!
351” Complete Intake to pan $2200
11.75:1, 351 cubic inches, Windsor style heads
351W Marine Block, ARP Main Studs
Stock Crank, 28oz External Balance
5.956” Long Eagle “H” Beam Rods w/ ARP Bolts
Icon Forged Std Bore Flat Top Pistons w/ Moly Rings
Pro Products 28oz Balancer
1964/65 289 Windsor Heads
Manley 1.94/1.60 Race Flow Stainless Valves
Extensively Ported
Manley Dual Springs for Solid Cam
Manley Moly Retainers
ARP 3/8” Rocker Studs w/ 5/16” Comp Cams guide plates
Speed Pro Full Roller Rockers
Cast Aluminum Ford Motorsports Valve Covers w/ Left Side Breathers
Speedway Cam
Sig Erson Solid Lifters w/ EDM oil hole
Ford Motorsports Billet True Roller Timing Set w/ 1 Piece Fuel Pump Drive
5/16 x .080 Moly Push Rods
Edelbrock Victor Jr Intake, ported and lightened
ARP Oil Pump Drive Shaft
Front Timing Cover w/ Stewart water pump
Rear Sump 9 Qt Speedway Pan w/Gates
Engine is currently assembled and has 18 nights of racing on it. No known problems.
I have been asked by several for various parts of this engine to be separated out.
Short block with pan and front cover $1650
Heads with valvetrain and rockers $500
Ported and Lightened Victor JR $250
Short Blocks:
Short Block #1 Sold!
351W Short Block #2 $350
.060 Over, KB Hyper flat top pistons with floating pins, 5.956” Cat “H” beam rods, Stock crank. Rotating mass is in ‘69/70 block but block may be too big after new hone is done. Includes another block that needs bored. Selling with the idea it will be put in the other block.
351W Short Block #3 $350
.030 Over, KB Hyper flat top pistons with floating pins, 5.956 Scat “H” beam rods. Comes with stock, 351W short block for crank and block cores. It’s a kit, you do the work!
Misc Engine Parts:
Quick Fuels 850 cfm Pro Series gas carb. Perfect condition, ready to go. $400
Russell Baker 390cfm gas carb. This is the ultimate 390. Passed IMCA and NASCAR gauges. Included 2 sets of metering blocks. 1 set of high compression (12.5:1 and over) and another set for low compression (under 12.5:1). $350
393 Stroker/351 Rods. Full set of used Scat 5.956” 351W stock length rods. These are “H” beam rods w/ ARP bolts, ready to use. $175 for the set.
Single World Products Windsor Jr. Head. Ported. Bare Head, just a single leftover. $150
Full set (plus 2 spares) of used KB/Icon Hyper .030 flat top pistons. Very nice condition. 351W pistons with pins. Been pin fitted and ready to put back into use. Set of 10 for $125
2 Sets of Hartman/Comp Cams ultra lightweight plastic valve covers. Very cool pieces. Thick rail for a good seal, uses long bolts so no rail crush is possible. $40 for a set/$75 for all.
Edelbrock/Roush intake. For early Yates style raised port heads. This will also work on a 351W with 351C 4bbl heads with a little work. Makes a neat combo. $300
Edelbrock Torquer II 351W intake. Painted black, nice condition, no bad holes or threads. $100
Pro Products Hurricane Intake (Victor Jr Copy). No porting, used 3 nights, like new. $150
Stock Ford 351W cast iron intakes. Several to choose from. Mostly 80’s van/truck intakes. Good for stock class or street. $50 each
sdllpark@netins.net
Delivery is available/possible if needed. You buy the gas. This stuff is in SE Iowa.
LM14
Re: Engines, Parts and Carb Selloff!!
Postby hoss429 on Tue Mar 05, 2013 5:32 pm
will the shaft rockers fit inline heads or canted valve?
hoss429
Postby LM14 on Tue Mar 05, 2013 7:03 pm
Inline valves.
We ran them on Brodix Track 1/IMCA spec heads. Have also had them on World Products Windsor Jr heads.
SPark
LM14
Postby LM14 on Sat Mar 09, 2013 7:30 pm
Updated List and added Baker carb
Thanks,
SPark
LM14
Postby LM14 on Fri Mar 15, 2013 12:59 pm
List Updated
Thanks,
SPark
LM14
Postby LM14 on Fri Mar 22, 2013 11:15 am
To answer a few questions we have recieved:
First off, nothing wrong with any of this stuff. We retired from racing and are selling off our inventory. Everything is as listed, no issues with anything, these are the parts we had in our cars/engines. The cars, trailer, some engines, trannys, spare parts, 4 wheeler, tires, wheels and shocks are already gone. This is what is left from our race team.
Yes, we will sell either complete engine without heads, intake or ignition. We'll sell them any way you want to buy them.
Yes, the 5.959 and 6.2 rods are matched sets, balanced and ready to use.
Sorry,no more Victor Jr intakes, they are all sold.
The only carbs we have left are the 2 listed, the Russell Baker 390 and the Quick Fuels 850. Nothing else.
I can deliver complete engines to your door. It runs $0.50/mile. That's what my gas costs. Not getting anything for my time.
We will entertain offers for everything combined. A few have asked, we will provide numbers however/whatever you are interested in buying.
These lists are updated every time I sell something. If it's listed, we probably still have it unless I've sold it in the past couple hours. I update every evening after sales.
PM me here or call 641-777-3584 for any questions or more info on anything.
Thanks,
Steve
LM14
Postby LM14 on Thu Mar 28, 2013 7:55 am
UPdated the list, added an intake, dropped some prices. Check it out!
SPark
LM14
Postby LM14 on Fri Apr 05, 2013 3:49 pm
List is updated.
I do not have any more distributors, ignition boxes, or oil pans.
The only carbs we have left are the 850 and 390 listed.
Thanks,
SPark
LM14
Postby LM14 on Wed Apr 17, 2013 5:58 pm
Sold a few pieces, marked some prices down again. Hit me with offers!
Thanks,
SPark
LM14
Postby LM14 on Wed May 01, 2013 8:29 am
Prices updated, engine parted out if wanted that way.
SPark
LM14
Postby LM14 on Thu May 16, 2013 6:37 pm
List and Prices Updated!!!!
SPark
LM14
Return to Parts For Sale
Users browsing this forum: No registered users and 2 guests
