1968 PONTIAC FIREBIRD
Need to get rid of that old car or project? Post it here.
Moderators: mokangena, DN, scottab, Carl Blanton, fish2222
Postby Kellys HotRod Garage on Mon Nov 19, 2012 1:04 pm
1968 Pontiac Firebird Street/Strip project car. The car has bucket seats, power steering, power brakes, original wiring harness, and was all working good before starting the project. The subframe is currently off of the car and being overhauled with all new body mounts, new motor mounts, new tubular upper and lower control arms with all new ball joints and bushings, new inner and outer tie rod ends, new 2" drop disc brake spindles, new 3 way adjustable drag shocks, new coil springs. All the glass is original and in great shape, doors and windows all work good. $5000
Also have new subframe connectors, new traction bars, new rear drag shocks, new aluminum rear leaf spring bushings, aluminum fuel cell, headers, and B&M ratchet shifter that can all go with the car for $6000
New 361ci Chevy Small block complete roller motor never fired. GM 350ci 4bolt main block freshly bored .060, new freeze plugs, square decked and line honed. New clevite rod,main,and cam bearings, new scat rods, new kieth black dome pistons, freshly turned steel GM crank, new chromemoly rings, new Compcams .630 lift mechanical roller cam, new pete jackson gear drive, new comp cams roller lifters, new pushrods, new aluminum heads with angle plug, stainless valves, screw in studs, new springs good up to .650 lift, new aluminum roller rocker arms, new aluminum valve covers, new melling oil pump, used aluminum high rise single plane intake, new Race Demon 750cfm carb with fuel log, HEI distributor, aluminum electric waterpump, aluminum mini starter, and tall K&N air filter.
Also NEW Turbo 400 racing tranny. Has 4500 stall converter, shift kit, manual valve body, reverse shift pattern, hardened gears, and tranny brake. Freshly built, never used. Take it all for $12,000 Please call 1-417-621-1841 or email kellyshotrodgarage@gmail.com for more pics or info
SHRUNK PIC3.JPG (189.63 KiB) Viewed 2633 times
SHRUNK PIC2.JPG (210.25 KiB) Viewed 2633 times
SHRUNK PIC1.JPG (228.21 KiB) Viewed 2633 times
Re: 1968 PONTIAC FIREBIRD
Postby Kellys HotRod Garage on Mon Nov 26, 2012 1:48 pm
MAKE OFFER :nice:
Postby mikethechevyguy on Fri Nov 30, 2012 11:58 pm
R those the wheels that go with or do u have matching set ? is the inside in good shape rust ?
mikethechevyguy
Postby OLD YELLER on Sat Dec 01, 2012 12:35 am
What type of rear axle does it have?
Postby Kellys HotRod Garage on Mon Dec 03, 2012 11:47 am
The wheels that go with it are the aluminum slot mags that are on the front. I have the full set of 4 that go with it.
Postby Kellys HotRod Garage on Mon Dec 03, 2012 11:51 am
The interior is in fairly good condition. Its all intact and would be usable for a driver. The car has a rust hole that needs patched on the passenger side floor board where it meets up with the firewall. And there are spots that are bubbling up the paint on the quarter panels, and there is bondo in the rear quarters also.
Postby mikethechevyguy on Wed Dec 05, 2012 12:19 am
is the sub frame back on the car ?
mikethechevyguy
Postby Kellys HotRod Garage on Tue Dec 11, 2012 8:19 am
The subframe is not on the car yet, but is ready to be bolted back on.
Postby billyswbchevy on Tue Dec 11, 2012 10:38 am
Do you have a title for the car?
billyswbchevy
Postby Kellys HotRod Garage on Tue Dec 11, 2012 2:26 pm
Yep car has title.
Postby billyswbchevy on Tue Dec 11, 2012 4:22 pm
interested in any trades? I have the black 82 swb posted here...its a nice truck..i maybe interested in a trade with you
billyswbchevy
Postby Kellys HotRod Garage on Sat Dec 22, 2012 8:46 am
ttt
Postby mikethechevyguy on Fri Dec 28, 2012 12:56 am
so if a guy buys will it b n parts or a roller
mikethechevyguy
Postby Kellys HotRod Garage on Fri Dec 28, 2012 8:02 am
It will be a roller. In other words, it will have the subframe finished and on the car and be able to be rolled on a trailer.
Postby Kellys HotRod Garage on Mon Jan 07, 2013 9:33 am
ttt
Next
Return to Cars/Trucks/Vans/SUVs For Sale
Users browsing this forum: No registered users and 2 guests
